Первые шаги в мир программирования под nanoCAD
пример работающего кода vbs (рисуем разрез стены с армированием)
Dim ms
Set ms = ThisDrawing.ModelSpace
Dim ut
Set ut = ThisDrawing.Utility
Dim oLine
Dim oDim
Dim point, point_sa
Dim xx
Dim yy
point = ut.GetPoint("0,0,0", "Укажите точку 1")
point_sa = ut.CreateSafeArrayFromVector(point)
xx = int(point_sa(0))
yy = int(point_sa(1))
Dim point2, point_sa2
Dim xx2
Dim yy2
point2 = ut.GetPoint("0,0,0", "Укажите точку 2")
point_sa2 = ut.CreateSafeArrayFromVector(point2)
xx2 = int(point_sa2(0))
yy2 = int(point_sa2(1))
dim dlina
dlina = xx2-xx
dim tsten
tsten = 200
dim dist
dist = 110
dim step
step = 400
dim scale
scale = 2
dim kray
kray = (tsten-dist)/2
dim q
q = int((dlina/scale - kray*2 - dist*2)/step)
dim dobor
dobor = 0
if (dlina/scale - kray*2 - dist*2)-q*step < 100 then
q = q-1
dobor = int(dlina/scale - kray*2 - dist*2 - q*step)
end if
line 0,0,tsten*scale,0
oLine.Layer = "КЖ_элементы Стм Фсм К Б"
line tsten*scale,0,dlina-tsten*scale,0
line dlina-tsten*scale,0,dlina,0
line dlina,0,dlina,tsten*scale
line dlina,tsten*scale,dlina-tsten*scale,tsten*scale
line dlina-tsten*scale,tsten*scale,tsten*scale,tsten*scale
line tsten*scale,tsten*scale,0,tsten*scale
line 0,tsten*scale,0,0
line kray*scale-20,kray*scale,(kray+dist)*scale+20,kray*scale
line (kray+dist)*scale,kray*scale-20,(kray+dist)*scale,(kray+dist)*scale+20
line (kray+dist)*scale+20,(kray+dist)*scale,kray*scale-20,(kray+dist)*scale
line kray*scale,(kray+dist)*scale+20,kray*scale,kray*scale-20
circle kray*scale+20,kray*scale+20,20
circle (kray+dist)*scale-20,kray*scale+20,20
circle (kray+dist)*scale-20,(kray+dist)*scale-20,20
circle kray*scale+20,(kray+dist)*scale-20,20
DimAlignedText 0,-50,kray*scale,-50,0,-200,kray
DimAlignedText kray*scale,-50,(kray+dist)*scale,-50,0,-200,dist
line dlina-kray*scale+20,kray*scale,dlina-(kray+dist)*scale-20,kray*scale
line dlina-(kray+dist)*scale,kray*scale-20,dlina-(kray+dist)*scale,(kray+dist)*scale+20
line dlina-(kray+dist)*scale-20,(kray+dist)*scale,dlina-kray*scale+20,(kray+dist)*scale
line dlina-kray*scale,(kray+dist)*scale+20,dlina-kray*scale,kray*scale-20
circle dlina-kray*scale-20,kray*scale+20,20
circle dlina-(kray+dist)*scale+20,kray*scale+20,20
circle dlina-(kray+dist)*scale+20,(kray+dist)*scale-20,20
circle dlina-kray*scale-20,(kray+dist)*scale-20,20
DimAlignedText dlina-kray*scale,-50,dlina,-50,0,-200,kray
DimAlignedText dlina-(kray+dist)*scale,-50,dlina-kray*scale,-50,0,-200,dist
dim i
for i=1 to q
line (kray+dist+i*step)*scale,kray*scale-20,(kray+dist+i*step)*scale,(kray+dist)*scale+20
circle (kray+dist+i*step)*scale+20,kray*scale+20,20
circle (kray+dist+i*step)*scale+20,(tsten-kray)*scale-20,20
next
if q = 0 then
else
if q = 1 then
 DimAlignedText (kray+dist)*scale,-50,(kray+dist+q*step)*scale,-50,0,-200,step
else
 DimAlignedText (kray+dist)*scale,-50,(kray+dist+q*step)*scale,-50,0,-200,step&"х"&q&"="&q*step
end if
end if
if dobor = 0 then
DimAlignedText (kray+dist+q*step)*scale,-50,dlina-(kray+dist)*scale,-50,0,-200,int((dlina/scale - kray*2 - dist*2 - q*step)/5)*5
else
line (kray+dist+q*step)*scale+int(dobor/2)*scale,40*scale,(kray+dist+q*step)*scale+int(dobor/2)*scale,(tsten-40)*scale
circle (kray+dist+q*step)*scale+20+int(dobor/2)*scale,25*scale+50,20
circle (kray+dist+q*step)*scale+20+int(dobor/2)*scale,(tsten-25)*scale-50,20
DimAlignedText (kray+dist+q*step)*scale,-50,(kray+dist+q*step)*scale+int(dobor/2)*scale,-50,0,-200,int(dobor/10)*5
DimAlignedText (kray+dist+q*step)*scale+int(dobor/2)*scale,-50,(kray+dist+q*step)*scale+dobor*scale,-50,0,-200,int(dobor/10)*5
end if
Sub Line(x1,y1,x2,y2)
Set oLine = ms.AddLine(CStr(xx+x1)+","+CStr(yy+y1)+","+CStr(0), CStr(xx+x2)+","+CStr(yy+y2)+","+CStr(0))
oLine.Layer = "КЖ_арматура элементов"
End Sub
Sub DimAlignedText(x1,y1,x2,y2,dx,dy,dimtext)
Set oDim = ms.AddDimAligned(CStr(xx+x1)+","+CStr(yy+y1)+","+CStr(0), CStr(xx+x2)+","+CStr(yy+y2)+","+CStr(0),CStr(xx+dx)+","+CStr(yy+dy))
oDim.Layer = "КЖ_размеры"
oDim.TextOverride = dimtext
oDim.ScaleFactor = "40"
oDim.TextInside = true
End Sub
Sub circle(x1,y1,dx)
Set oLine = ms.AddCircle(CStr(xx+x1)+","+CStr(yy+y1)+","+CStr(0), CStr(dx))
End Sub
ну ядрена копоть!
Dim pline, cc, coords(5), pline_coords_str
'method 1
coords(0) = 0
coords(1) = 0
coords(2) = 10
coords(3) = 20
coords(4) = 30
coords(5) = 40
set pline = ThisDrawing.ModelSpace.AddPolyline(coords)
'method 2
pline_coords_str = "0;0;0;100;0;0;100;100;0;0;100;0;0;0;0"
set pline = ThisDrawing.ModelSpace.AddPolyline(ThisDrawing.Utility.CreateTypedArrayFromJSArray (5, CStr(pline_coords_str)))
АХТУНГ : для метода 2 есть 2 тонких момента
1) стринг с координатами надо явно кастировать к стрингу - (CStr(pline_coords_str)
2) результат CreateTypedArrayFromJSArray нельзя засовывать в переменную, надо использовать сразу
все это из-за того, что иначе лишний референс получается.
о, спасибо!
а такой вопрос ещё вдогонку. я некоторые координаты вычисляю, и если есть деление, то ясен пень иногда получаются дробные значения, типа "0,5"
и когда передаю их в AddLine, они воспринимаются не как одна координата, а как две (через запятую) =(
приходится загонять вычисления в int()
можно это как-то иначе решить?
вот так, например, норм:
Set oLine = ms.AddLine(CStr(int(xx+x1))+","+CStr(int(yy+y1))+","+CStr(0), CStr(int(xx+x2))+","+CStr(int(yy+y2))+","+CStr(0))
а, ну и самый взрыв мозга - как в полилинию добавить дугу сразу? =)
Edited by swell{d}
дробные значения надо загонять через точку! ("0.5")
а дугу в полилинию сразу - никак. то есть вообще. там на самом деле для каждого вертекса куча параметров, на все сочетания никаких методов создания не напасешься. так что создать "как проще", а потом рихтовать по месту.
жалко. а то у меня есть такие миленькие каркасы, нарисованные полилинией. думал сделать их вставку на кнопку.
придётся копировать уже нарисованные....
Ну, вообще-то ни одна зараза не мешает написать свою обертку вокруг создания полилайна, и просунуть в нее все, что нужно, для создания дуговых сегментов.
  • 1 year later...
Вопрос по LISP
Чем можно заменить функцию nentsel (которая отсутствует в NANOCAD)?
Прилагаемый файл не работает в NANOCAD
mt2ml.lsp
NENTSEL функция не определена
ошибка: неверный тип аргумента: LENTITYP: nil
Edited by BOSS_2014
  • 1 month later...
Задам вопрос здесь, хотя скорей всего это и не связано с программированием. Суть в том, что простенькая функция:
(defun pl_styles (/ lst lyr)
   (setq lst (list (cdr (assoc 2 (tblnext "STYLE" T)))))
   (while (setq lyr (tblnext "STYLE"))
     (setq lst (cons (cdr (assoc 2 lyr)) lst))
   (reverse lst)
возвращает один "лишний" стиль "". Через объектную модель этот стиль тоже найти можно. Значит он сидит где-то в базе чертежа? Но нанокад его не отображает, то есть только программным способом к нему можно получить доступ. Если мне не изменяет память, эта ошибка была в ранних версиях брикскада, а значит происходит от библиотек ода, имхо.
Собственно вопрос: это нормально, если нет будет ли исправлено и когда, если будет
  • 1 month later...
Может быть кто-нибудь знает в чем секрет?)
Пишу скрипт на JS.
В Нанокаде 5.0 при ошибке в скрипте он выдавал описание, из-за чего ошибка, в какой строке скрипта.
В Нанокаде 6.0 при ошибках он просто ничего не делает, никаких сообщений об ошибке не выводит.
  • 1 month later...
Подскажите, а имеется ли справочник по javascript функциям? Было бы очень интересно полистать. (в справке к программе не узрел)
А конкретно сейчас меня интересует функция заливки области.
Edited by ahapych
это не относится к java...смотрите SDK по ModelSpace nanoCAD...
Извините, но нашел только функции для построения линий, лучей, окружностей, эллипсов, однострочного и многострочного текста. Вряд ли список возможностей ограничивается этим...
  • 3 months later...
Помогите нужно установить слой 0 текущим.
Все перепробовал не получается.
Что я делаю не так?
'Подпрограмма-функция установления слоя "0" текущим.
'Толщина линии задана жестко - по слою
Sub LAYER_0()
Dim layer As AcadLayer 'переменная типа "слой"
Set layer = ThisDrawing.Layers.Add("0") 'создаем новый слой и присваиваем ему имя
layer.Color = 7 'устанавливаем цвет слоя
layer.LineWeight = acLnWtByLayer 'толщина линии - "по слою"
ThisDrawing.ActiveLayer = layer ' переключаем текущий слой на созданный
End Sub
скорее всего, засада в том, что слой 0 создавать не надо - он всегда есть. так что всего и делов-то :
ThisDrawing.ActiveLayer = ThisDrawing.Layers.Item("0")
или даже
ThisDrawing.ActiveLayer = ThisDrawing.Layers("0")
'Подпрограмма-функция установления текущим слоем "0".
'Функция устанавливает текущим слой "0"
'Толщина линии и цвет заданы жестко - по слою
Sub LAYER_0()
Dim layer0 As AcadLayer 'переменная типа "слой"
Set layer0.Color = Colorlayer 'устанавливаем цвет слоя - "по слою"
layer0.LineWeight = acLnWtByLayer 'толщина линии - "по слою"
ThisDrawing.ActiveLayer = ThisDrawing.Layers.Item("0") ' устанавливаем текущий слой на "0"
End Sub
не работает почему-то. Хотя вот эта часть работает без нареканий:
'Подпрограмма-функция создания слоя и установления его текущим.
'Функция создает слой присваивает ему имя, цвет (задается пользователем) и устанавливает его текущим
Sub MY_LAYER(Namelayer As String, Colorlayer As Byte)
Set layer = ThisDrawing.Layers.Add(Namelayer) 'создаем новый слой и присваиваем ему имя
layer.Color = Colorlayer 'устанавливаем цвет слоя - "по слою"
End Sub
Edited by Lion2032
Sub LAYER_0()
End Sub
тогда уж не так...
Sub LAYER_0()
Set layer0 = ThisDrawing.Layers.Item("0")
ThisDrawing.ActiveLayer = layer0 ' устанавливаем текущий слой на "0"
End Sub
хотя, вообще-то, есть резон проверить сначала - а надо ли менять параметры слоя
Параметры менять надо.
Но все равно не работает (((
Извините, если я не понимаю простых вещей
Мдэ... на параметры я что-то внимания не обратил.
значится, так...
вот у нас есть слой. у него есть свойства - например color и lineweight. а теперь попробуем представить, каким образом у СЛОЯ может быть цвет ПО СЛОЮ? правильно, никаким!
с лайнвейтом - ровно та же штука. то есть эти параметры слоя должны быть заданы ЯВНО.
ByLayer - это могут быть параметры у конкретного объекта. так что тут надо как-то это не так делать...
не. тут фокус в другом. у слоя не может быть цвет "по слою" - откуда он его должен взять? тут может быть только конкретный цвет - красный, зеленый...
а "по слою" - это только у объекта. у линии например.
Понял, нужен белый (в смысле: черно-белый ) и толщина 0,0
Dim Colorlayer As byte 'задаем переменную явно
Set Colorlayer = 7 'задаем параметр по слою
Так?
Edited by Lion2032
