slovak Posted April 27, 2012 Report Share Posted April 27, 2012 Уважаемое сообщество! Собственно написал скрипт, который рисует циклоиды: Dim oLine Dim oCircle Dim A(2, 2000) Dim NumberPoints Dim phi Dim alpha Dim pi Dim Count Dim Rb Dim Rm Dim k Count = 0 pi = 3.1415926 alpha = 0 Rb = 10 Rm = 2 NumberPoints = 360 k = Rb/Rm for phi = 0 to 2*pi step pi/180 Count = Count + 1 A(1, Count) = Rm*(k - 1)*(cos(phi) + cos((k - 1)*phi)/(k - 1)) A(2, Count) = Rm*(k - 1)*(sin(phi) - sin((k - 1)*phi)/(k - 1)) next for phi = 0 to 2*pi step pi/180 Count = Count + 1 A(1, Count) = (Rb + Rm)*cos(phi) - Rm*cos(alpha + ((Rb+Rm)/Rm)*phi) A(2, Count) = (Rb + Rm)*sin(phi) - Rm*sin(alpha + ((Rb+Rm)/Rm)*phi) next Set oCircle = ThisDrawing.ModelSpace.AddCircle(CStr(0)+","+CStr(0)+","+CStr(0), Rb) Set oCircle = ThisDrawing.ModelSpace.AddCircle(CStr(Rb + Rm)+","+CStr(0)+","+CStr(0), Rm) Set oCircle = ThisDrawing.ModelSpace.AddCircle(CStr(Rb - Rm)+","+CStr(0)+","+CStr(0), Rm) for i = 1 to Count - 1 Set oLine = ThisDrawing.ModelSpace.AddLine(CStr(A(1, i))+","+CStr(A(2, i))+","+CStr(0), CStr(A(1, i + 1))+","+CStr(A(2, i + 1))+","+CStr(0)) 'Set oLine = ThisDrawing.ModelSpace.AddLine(CStr(0)+","+CStr(0)+","+CStr(0), CStr(A(1, i))+","+CStr(A(2, i))+","+CStr(0)) 'Set oCircle = ThisDrawing.ModelSpace.AddCircle(CStr(A(1, i))+","+CStr(A(2, i))+","+CStr(0), 0.01) next Пытаюсь отрисовать их с помощью полилинии. Для проверки работоспособности пытался нарисовать полилинию: Dim varVertList(8) Dim objPLine varVertList(0) = 0 varVertList(1) = 0 varVertList(2) = 0 varVertList(3) = 10 varVertList(4) = 10 varVertList(5) = 0 varVertList(6) = 10 varVertList(7) = 50 varVertList(8) = 0 Set objPLine = ThisDrawing.ModelSpace.AddPolyline(varVertList) В результате получаю: err: "TeighaX" raised an exception "Параметр задан неверно." at line 17 pos 0 Set objPLine = ThisDrawing.ModelSpace.AddPolyline(varVertList) ^ В каком виде должны быть координаты вершин в массиве varVertList для отрисовки полилинии? Пробовал строкой как для отрезка ("x,y,z") - тоже не вышло. Заранее благодарю за ответ! К стати, в первом листинге не корректно отображается подсветка синтаксиса строки: 'Set oCircle = ThisDrawing.ModelSpace.AddCircle(CStr(A(1, i))+","+CStr(A(2, i))+","+CStr(0), 0.01) Строка начинается с " ' ", но не отображается зеленым. 1 Quote Link to comment Share on other sites More sharing options...
ISL Posted May 2, 2012 Report Share Posted May 2, 2012 В текущей версии создать LightweightPolyline из VBScript нельзя, поскольку VBScript передаёт VT_ARRAY|VT_VARIANT, тогда как OdaX ожидает VT_ARRAY|VT_R8. Проблема известна и исправлена, войдёт в следующую сборку. 1 Quote Link to comment Share on other sites More sharing options...
slovak Posted May 7, 2012 Author Report Share Posted May 7, 2012 В текущей версии создать LightweightPolyline из VBScript нельзя, поскольку VBScript передаёт VT_ARRAY|VT_VARIANT, тогда как OdaX ожидает VT_ARRAY|VT_R8. Проблема известна и исправлена, войдёт в следующую сборку. Большое спасибо за ответ! Quote Link to comment Share on other sites More sharing options...
