Вывод координат точки
In nanoCAD, you can display the coordinates of points (including points inside blocks) by using the “List Coordinates” command. Here’s a simple method:
  1. Use the command: Tools > List Coordinates.
  2. Select the point you want the coordinates for (even inside a block).
  3. The X, Y, Z coordinates will be displayed in the command line.
Alternatively, you can also try using the “Snap” tools to create dimensions with coordinates, similar to how it’s done in AutoCAD. If you need more flexibility, nanoCAD has an API where you can create custom commands to automate this process.
It’s great that nanoCAD provides multiple ways to display coordinates, including inside blocks! The “List Coordinates” command sounds straightforward, and using Snap tools for dimensions is a useful alternative. The API feature adds even more automation flexibility.Your strategy tip about delaying weapon production to gain time before an attack is interesting—clever tactics can make a big difference in gameplay and resource management!
… хорошо бы переводчика сюда :).
Да был у нас один…
Мы его в кипятке и сварили… (цитаты из знаменитого фильма “Иван Васильевич меняет профессию”).
Паки, Паки …
Все молодцы, все свободны!
